I just replaced the transom, stringers and floor in my boat. Thus I had to remove the engine. 1972 Mercruiser 140 with type I stern drive, of which I also replaced the gimble bearing. I borrowed the engine aligment tool from my local boat shop.<br /><br />I have adjusted the engine, front A arm type adjustment only as rear mounts to the transom plate, and the tool slides into the engine about 1 to 1 1/2 inches easily, indicated by the spline impression left in the grease I applied to the end of the tool. How far should the tool slide into the engine? Am I good to go or do I need to do more adjusting?<br /><br />Thanks for any help!
