Mercruiser Engine '96 RPM drops to +/- 2900 rpm after one hour
leogetz
Hi All,<br /><br />Here's a problem from the Netherlands..<br /><br />I've a '96 Celberity 200SS with a Mercruiser 4.3 v6 alpha 1 LX. 190 HP , run for 250 hours now.<br /><br />The problem is , that it drops in RPM after about 1 or 2 hours driving. This first hour(s) it runs fine, about 5000 RPM , 45 mph.<br />After that it wont go higher than about 3000 RPM. If I stop and wait for about 15 minutes it goes fine again for another 30 minutes and so on.<br /><br />Does anyone have ideas about this ? <br /><br />Thanks in Advance..<br /><br />Leon
Bob_VT
Re: Mercruiser Engine '96 RPM drops to +/- 2900 rpm after one hour
Welcome to iboats! Sometimes that indicates a coil starting to go. They are affected by heat and I have seen them go bad only when hot.<br /><br />Bob
lindb40530
Could be a clogging fuel filter. You might have sediment in the tank that gets pulled into the fuel filter. After a while of running they build up and clog the filter. When you shut it down, the gas runs back partially unclogging. I would replace the filters, and check the tank.
leogetz
Thank you for replies, Lindy and Bob.<br /><br />Bob, I'm dutch , and can't figure out what you meaning with 'coil'. Is there another way to explain this ? (sorry for my bad english..)<br /><br />Linday, where do you think those filters are hide ? Near the tank, or near the engine?<br />And is there a way to check the tank, since I thought you can't open them ?<br /><br />Thank you all very much!<br /><br />Leon
Well Leo,<br /><br />I don't speak Dutch either......<br /><br />But,<br />If you don't know What the Coil Is,<br />And,<br />Can't find the Fuel Filter ,<br /><br />I Think you Need a Mechanic,<br />Not a Translator..........
akriverrat
an hour at 5000 rpm? TWO hours? it just needs a break. what is the wot range on a 4.3?
rodbolt
hello<br /> on an american boat there is an anti-siphon valve on the tank. some tanks have a fuel filter in the draw tube for the tank. does you hull have a water seperating fuel filter? also if its EFI it will have filters that can clog. any alarms or other abnormal indications> I am almost with bondo. you may get in over your head if your not careful. the Coil is the inductive transformer that uses a collapsing primary magnetic field to induce a high voltage field across the secondary windings.<br /> its can give problems occasionally
hoot
the coil on boats is a cylinderical object, about 15cm long, 6cm in diameter. it has two small screw posts on one end and a larger hole in the middle with an ignition wire stuck in it coming from the distributor. it should be mounted close to your distributor, the plastic looking thing with 7 wires stuck in it running to the spark plugs and coil.
bomar76
If he runs that mill for an HOUR at 5 grand, maybe the next hour the valves are trying to catch up!!! :rolleyes: :) :confused:
leogetz
The problem is fixed. On the tank, there;s bullit which keeps the fuel on pressure, so that the fuel pomp doesnt need to fill the complete fuel drain again each time. This 'bullit' was stuck a little. After removing this pain in the *** it runs like hell again! Thanx for the tips..
