Does anyone know where the Neutral Safety is on this motor. I think either it is bad or the wires connecting to it from the harness are loose. Its a new boat - 2006 w 30 hours. ( Chapparal w Dual motors )
MERCRUISER (1.7 MS 120 WPS)
Serial Number: 88110205
I have a port motor that will not start - no click, nothing. Battery good, starter will jump at starter motor, no ignition power to slave relay when I turn key, test light lights up on the 'start' terminal at the Key switch when turned to start - so we have power going down the line when the key turns.
I have checked out the diagrams on mercury parts express with the above serial number, but cant seem to see the neutral safety.
I have a feeling its the neutral safety connection between the harness and the switch, but I can find it !!
I have a quicksilver dual remote console mounted at the helm ( newest model ) and according to the diagram on same website, there is no neutral safety in that remote, apart from the emergency cut off switch attached to the laynard, which is not the issue here.
