CampionGuy
- Jun 24, 2007
- 58
Hi all,
I am new to the forum and have a question that I believe some of you may answer.
3.7l mercruiser w/Alpa 1 leg, 21.5' Campion Discovery both 1988 vintage.
I seemed to lose battery voltage on sea trial when the engine was hot, after cooling (possible battery regeneration?) power was restored but still somewhat weak. After managing to get the boat home and running it on muffs I found that the #1 battery was charging a full 14.88v but #2 was showing only 12.4v I am using a perko battery switch which I previously removed and cleaned all terminals and all connections to a mirror finish as well as the connectors at the batteries. While running I use the "both" selection on the switch. I can't honestly say that this was or wasn't a pre-existing condition as this was the first trip this year. (late I know but surgeries prevailed)
Shouldn't the batteries both be charging while engine running?
Thanx in advance,
Doug
Thanx in advance,
Doug
