I have a 1989 Rinker Captiva 206 with a Mercruiser 5.0LX Alpha 1 drive with 600 hours in the clock. It's the 230 hp model with a Rochester Q-jet carb. Here's my problem. The boat starts fine and runs well until it's fully warmed up. Then it will start to load up at idle and stall as throttle is insreased. I've checked the obvious things; choke, fuel pump and filters. I suspect it's the carb and will attempt to rebuild it myself using the Sierra rebuild kit. Is there something else I shouid try prior to doing this? Once rebuilt, how much adjusting and fine tuning will be necessary? I'm told that even a new or remanufactured carb will require the same amount of fiddling. Thanks in advance for the help.
