Hi All,
I was installing a hydrofoil stabilizer on my Bravo 1, when a little plastic plug piece, designed simply to cover the bolt hole, fell into the aftward facing opening on the outdrive, just above the cavitation plate. I am not sure where this passage leads to (gears, water impeller, etc. ), so I don't know if it will be OK to run, or whether I need to take apart the gear casing to get this little piece of plastic out.
Any info would be helpful. Let me know if I need to provide more information.
Thanks,
Dan Orchard
Thanks,
Dan Orchard
