MY BOAT HAS A RESERVOIR IN THE ENGINE COMPARTMENT FOR THE GEAR LUBE. I JUST NOTICED THAT THE LEVEL IS A LITTLE BELOW THE FILL LINE. THIS BOAT ONLY HAS ABOUT 9 HRS. ON IT. IM PRETTY SURE THAT THE RESERVOIR WAS FULL WHEN I BROUGHT IT HOME. IS IT NORMAL TO GO THROUGH THAT MUCH OIL? IF SO WHERE DOES IT GO? IT STILL HAS ABOUT 3/4 TO 1 INCH OF OIL IN THE RESEVOIR, IS IT SAFE TO RUN?
