I have a 1989 Chaparral 198 XL C with I/O Mercruiser, 4 Cyl pretty well maintained & inside a garage when not on the water. Beginning of this boating season, changes Antifreeze and oil. Lower unit good from servicing 1.5 years before. It usually pulls skier out of water at about 3500-3800 RPM. This year I saw the RPMs were higher than normal with/without load (500-1000 RPM more). Also the RPM bounces around more (maybe my imagination). I researched in the pages of this wonderful forum and there was the discussion of props that can strip out and cause symptoms like a slipping clutch in a car. That seemed to explain it, so I replaced the prop. Went out this weekend- No change. So we had fun with high RPM's then coming in at the end of the day (2 mile trek), I heard this pop, like a bulk door flying open and my wife even looked for that. I thought it came from back. 2-3 minutes later it happened again, and I felt the boat slow abruptly for sec then continued on. I nursed it in the rest of the way without problems. Then, on Sunday back out again same thing higher than normal RPMs then at the end of the day on the way back, popping again, with abrupt short hesitation in boat. I see in the pages of this great site similar examples where it was the engine, this doesnt seem to be the engine, sounds like the drive to me. Scares the crap out of me.
Thoughts are appreciated
