Mercruiser Alpha One Gen Two Bellows
CRod
Hello all. I'm having an issue finding the correct drive shaft bellow for a 1999 Alpha One Gen Two sterndrive. The issue is that the inside of the gimbal housing is made for a bellow with a squared edge and the only bellows we can find have a rounded edge and won't seat. I've been told that my only option is to replace the gimbal housing. 20220628_115439.jpg20220628_115430.jpgAny ideas would be greatly appreciated. Thanks in advance.
flashback
The picture you posted is the old one correct? If so it sure looks proper.
CRod
Thank you. Yes, the pics posted are of the old dirty bellow. The new bellows they've tried, about six different ones, all have a rounded lip on both ends, but the gimbal housing won't seat a rounded bellow, it rolls out of the seat when trying to press the seal. Would you know of a part # for the bellow that has the square edged lip?
Ayuh,..... Welcome Aboard,..... Is the lockin' ridge in the gimbal housin' nice, 'n clean for the bellows sit in/ on,..??
The squareish/ rounded extreme end of the bellows, is Beyond the internal aluminum lockin' ring,....
Scott06
Did you get oem merc bellows if not try one
or get the whole oem transom kit . I just did mine fit perfectly including the exhaust bellows
