Smokey988
- Sep 7, 2019
- 40
Hello all,
I just recently purchased a 2007 Four Winns H183 Fish and Ski with 214 hours on it and have been checking all the fluids before every trip out and all fluids had good color and levels.
Today I noticed a small oil slick when loading the boat back on the trailer so I decided to check all the fluids again. When I removed the fill vent on the sterndrive I was shocked to see white oil (watery oil) come out. I went to check the Gear Lube Monitor mounted on the Merc 4.3 and it was full and bulging with pressure. When I released the cap fluid came out and spilled over into the bilge.
I immediately drained the gear oil from the lower unit as well as the Gear lube Monitor and did a quick pressure test. I only went to about 8lbs but it did not drop at all after 10 minutes.
What am I missing? Would a leak not have to be present for that amount of water to get into the sterndrive? And I am 100% sure the gear oil was in good condition prior to today's trip out.
I appreciate any input.
Thanks
Thanks
