Jim Robbins
- Jun 15, 2005
- 85
Mercruiser (A508384) Info., year, H.P. etc
Hello, I bought a 1986 Chris Craft 210 Scorpion LTD ($900.), with mercruiser motor A508384,
8 cyl. , what motor info. can you tell me? What boat info. can you tell me?
The motor has been sitting (winterized) for 2-3 years, I think. Motor turns over fine, I didn't try to start up. I was going to remove the plugs and spray some lubrication into each cylinder, and turn over motor with the plugs out (yes / no ).
How can I pump out the old gas from the tank? Have the impeller changed. Change oil & lower end fluid, change plugs, fuel filter, clean spark arester on carb., check/clean points, distibutor.
What else should be done before trying to start, by me or marine mach. Thank-you for any and all advice!
