So I took my project boat out for a test today and ran into some frustrating issues.
History is
- New Plugs
- New Wires
- New Dist Cap and Rotor
- New oil filter
- New fuel filter
- Carb cleaned and assembled with new gaskets
- Fresh Gas
- New Ignition Coil
- Timing Set 8 * btdc
Preliminary testing was good. Boat fires right up, revs to about 4200 rpm. Engages forward, Engages reverse. Does not stall or spit and sputter.
So on the lake... I get it off the trailer, fire it up , put it in reverse and it stalls.
Crank it back up, put in reverse, stalls.
SO i make it over the dock, get a good push off and put it in drive, it stalls.
SO when it first goes into gear the carb back pops.
I adjust timing on the lake. No better.
I am able to get it into drive and idle out of the cove I docked in. Any throttle response is instant death.
I checked the ESA (neutral switch) , disabled it, put it in drive, still stalls.
I am down to possible fuel pump or carb setting.
Is there a way for me to test the motor under load without being in the water?
Can I replace the mechanical pump with an electric pump?
What else could be in the circuit causing this issue?
I can place the motor in neutral and rev without issue.
History is
- New Plugs
- New Wires
- New oil filter
- New fuel filter
- Fresh Gas
- New Ignition Coil
