Mercruiser 7.4L V8 Bravo compatability with an Alpha One
STINGER23
I have a big block in my go-fast boat....Mercruiser 7.4L V8 Bravo. The boat has an Alpha outdrive. I was told that the Alpha drive + my big block will not work well....and that the drive would "grenade" in no time.
Is it true that i can end up with a blown Alpha, because the power my big block puts out?
Uploaded with ImageShack.us
Thanks!
Re: Mercruiser 7.4L V8 Bravo compatability with an Alpha One
Ayuh,.... Absolutely,.... Count on it....
The Alpha drives are rated to 300hp,... yer motor is rated at 330hp...
Yer motor is also not the original,....
It came out of a hull with a Bravo drive, as Bravo is a drive tag, not related to motors...
pretty nasty lookin' too...
The Life of the drive is totally dependent on the actions of the Operator's righthand....
Be easy, it'll last quite awhile,...
Mash it, 'n All bets are off....
Launch it, 'n ya need another drive...
Friscoboater
Yep, someone changed the drive out to the lesser Alpha at one point, or just bought a flame arrestor cover.
ENSIGN
I would not try to see (how fast will it go ???)
dubs283
are you sure you have an alpha drive??
its tough to tell from the photo and i don't see any wires going to a shift interrupt switch on the shift plate in the engine photo
someone would have to REALLY want to install an alpha behind that engine if the boat originally had a bravo - its a lot of different parts and work to do so
take some close up photos of the drive and STBD side manifold riser/shift plate assy then we will know what you are dealing with
IF you do actually have an alpha drive on your boat you do not have a "go fast"
Don S
It would be a go fast for a couple of times :p
tpenfield
It is borderline with that engine . . . some of the standard 454's had 330 hp, and later years they had 310 hp.
So, if you 'baby' it, then it may survive. If you do a fair amount of the GFBL thing, then have your Sea Tow membership up to date.
Don't tell any of your GFBL friends about this either, as they probably all have Bravo drives. :)
Ayuh,... It's an Alpha 1.... This is in his other thread,....
I have a 1984 Chris Craft Stinger with a Mercruiser Bravo 7.4L...its 454 cid...
Im looking for an engine manual and all the info to look up the engine online, but cannot find it.
Can anyone help?
All I know is:
Mercruiser
454 c.i.d
7.4L/V8 Bravo
Thunderbolt Igniton/Power steering
Thanks!
Sam
I'm thinkin' this boat started out with the 260hp/ Alpha 1....
Somebody's stuffed a BBC in it,.....
A pretty rough lookin' 1 at that....
O-fishal
Wheres the skeg?
Don S
Wheres the skeg?
Actually, the skeg hates to be away from the boat, and is camera shy. So when the drive is removed, the skeg is removed from the drive and placed just under the boat out of camera view ...........
Here's your sign. :facepalm:
O-fishal
HA HA:redface:
Thalasso
Is that the fuel/water seperator lying on the floor.
Pete104
She's a beauty!
MSFAB
I would say if you had a light weight boat then you would be fine but the stinger 23 is a heavy boat. i have a 87 baja 220 sport with a stock 330 454bbc and an alpha 1 drive and have had 0 issues with it and i beat the **** out of it 60mph+ on a regular basis but the boat only weighs in at 2200 pounds.
jerryjerry05
You can hook up a BB to an Alpha.You will need to re-gear the upper.It's a 1-32-1 or something like that.
It will work and work good.I wouldn't expect it to last forever as it really needs a Brovo or bigger.
Friend had a Donzi with twin 454's and Alpha drives and it worked great.Just install drive coolers.
It wasn't a race boat but got about 60.Jasper sells the reman upper and from the looks you need a lower case.
Just send it all to Jasper.J
