Mercruiser 5 L EFI no gas or spark
affa
Hi
I changed oil and filters on my engine, everything looked Ok when I started up, but when I should start A little bit later it wouldn´t start. There is no fuel to the carb and no ignition, but the fuel pump starts and try to deliver, The mecanic told me to change the modul distributor and module assy knock, but that didn`t help, and now I don`t hear the sirena or the fuel pump when I turn the key, Any ideas?
Regards
Affa
Ayuh,.... Start at the battery, 'n clean to shiny metal Clean, all the wirin' connections to the starter, includin' the grounds, 'n both ends of all the wires,.....
alldodge
Kind of hard to understand but maybe English is not you first language. If your turning the key and hear nothing, then check the 20 amp fuse going to the key switch. Follow the Red/Purple wire back to the fuse
achris
More fish than mountain goat
.... but maybe English is not you first language....
At a guess, I'd say Norwegian, around Bergen way.... :D... Been there, recently. ;) It's COLD! even in summer. :eek:
I suspect you may have knocked something while doing the oil and filter change. Check everything is plugged in and all the fuses are ok.... After that, you may need to plug the diagnostic software in to find what the ECU is not seeing...
Chris........
jrs_diesel
Going out on a limb here, but your safety lanyard switch didn't get pulled out did it?
affa
Thanks I`ll check these things
Yes you`re right about close to Bergen, last summer was terrible, but we had a warm summer this year,
