I know this has been discussed before, but?
Been researching a lot here, but now I need to put something out for some help/advice. Quick backstory and history. Mid-season last year picked up a 23 foot maxum with a Mercruiser 5.7LX, 4 bbl with a Thunderbolt V ignition. It had a random backfire through the carb at higher RMP?s (3400+) that was attributed at the time to be old fuel?as in maybe a year or more without treatment and stored off season (and boat was barely used during this time as well). Engine would recover with a slight pull back on the throttle, but could never get to WOT without the backfire. Prior to buying had a mechanic do a tune up (plugs, cap & rotor), and give a once over (compression, leaks, etc). Got a good report in that the motor was mechanically sound, and issue seemed to become more infrequent, but again could not quite get to WOT. During this time was adding Startron additive to fuel and replaced fuel filter/water separator. Took a chance as I could not pass up for the price!!
Flash forward to this season, coming out of storage (indoor, climate controlled..I live in Michigan) it ran horrible! Constant back fire that started at 2800 RPM and got worse as engine warmed up. Since this was more consistent, I did some research and looked more closely at ignition. Long and short, I found a HEAVILY corroded ignition sensor (looks to be original) mounted in the distributor, as well as nasty looking wires and coil. Replace all with OEM, interesting the sensor PN has been updated and replaced six times since the one I was replacing. It is now completely encapsulated in epoxy and has an added ground wire. While I was at it, I removed and cleaned all ignition grounds as well as remove and cleaned the connections to the Ignition Control Module and Knock Control Module mounted to side of distributer. Took her out and ran MUCH better, good cruise at around 3400-3600, smooth acceleration?..but?I?m back to where I was last year, getting a random backfire through carb at higher RPM?s and can?t get to WOT, engine recovers with slight throttle pull back. Also seems that anything above 3000 I need to gradually increase throttle or I get a random backfire?.seems like it?s a lean condition now maybe, carb rebuild? I know really old fuel left to sit in a carb can gum up and varnish passages, jets, float, needle & seat.
Sorry for lengthy explanation, but want to provide as much info as possible. While I am no marine expert, I consider myself a pretty good backyard mechanic, but am getting pretty frustrated.
