can i put on a mercruiser 5.7l tks alpha a ignition control module from a 5.0 tks alpha? thanks!
B bursucul Recruit Joined Feb 4, 2019 Messages 3 Feb 4, 2019 #1 can i put on a mercruiser 5.7l tks alpha a ignition control module from a 5.0 tks alpha? thanks!
B bursucul Recruit Joined Feb 4, 2019 Messages 3 Feb 4, 2019 #2 ignition is thunderbolt V,control module is denso.
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 51,868 Feb 4, 2019 #3 with or without the knock sensors?
Scott06 Admiral Joined Apr 20, 2014 Messages 7,319 Feb 4, 2019 #4 In a word yes will work, I've done it. I think the 5.0 doesn't have quite a small much advance and I suspect you have no knock sensor on the 5.0 module. Verify that youre getting like 26 degrees advance all in and it should work.
B bursucul Recruit Joined Feb 4, 2019 Messages 3 Feb 4, 2019 #5 without knock sensor! so guys you said it will be work?thanks again!
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 51,868 Feb 4, 2019 #6 without knock sensors it will work. 2 more degrees of advance, however not enough to worry about if you had knock sensors, then it wouldnt work as the knock tuning would be off.
