I need to pull my Mercruiser 5.7L engine to change out the oil pan and timing cover. Am looking at renting an aluminum gantry with 10 ft span and high lift for added safety but looking for cheaper (also safe) options if anyone has had good luck with a different approach. I have an 8 foot beam with boat on trailer so would need a fairly high lift. My garage has all the height I need but need to get the motor up high enough to work on it, preferably out of the boat and on a stand to rotate it. Homemade wooden gantry is too risky for me and isn't a road I want to go down. Thanks.
