The engine is a 1996 5.7l 2 barrel, with an alpha one gen 2 drive. This was my first summer with the boat, and it has been fine up until my last day out. I kept the boat in a covered slip on a lift and used the boat every weekend. I usually don't go too far from the marina with it. On our last day out we went to a bay maybe 8-9 miles from the marina. I cruise at about 3400 rpms while running about 30-35 mph.
On out way there I noticed the boat would bog down every once in a while, but would clear up and get back to cruising speed. On the way back it got a lot worse, it would bog down every few seconds. It would backfire also. If I let off the throttle a bit I could get it to clear out and get back up to speed for a few seconds, then it would start bogging again. The engine never completely died, and it would idle in gear all day long without any problem. There have been a few times throughout the summer when I would have the engine idling in our slip while loading the boat and it would just die. It always started right back up, so I wasn't very concerned at the time. Not sure if these 2 issues are connected or not.
I changed the fuel/water filter and the backfiring seemed to be gone, but it would still bog badly at cruising speed.
I removed the anti-siphon valve from the fuel tank and it seems to be working fine. I tried to blow through my fuel tank vent while the anti-siphon valve and fuel line (to the engine) was disconnected, and could not blow through the vent. If I opened the fuel filler cap then I could blow through the vent fine. Im not sure if I should have been able to blow through the vent hose with the fuel filler closed or not.
I read online to try to run the boat off an external gas can to see if that helps, but I have not been able to do that yet. Once the boat started messing up I brought it home for the winter. I live about an hour from the lake, so I would like to try a few small things at the house before I take it to the lake again. I'd like to fix the issue before winter comes and I have to winterize it.
Sorry for the long post, but hopefully I gave enough info (an then some!) to help point me in the right direction.
