Mercruiser 5.7l carb, audible alarm test does not sound unless the trim up/down button is pressed
aqua123
Mercruiser 5.7l carb, audible alarm test does not sound with key in on position unless the trim up/down button is pressed. Can someone point me in the right direction to fix?
Ayuh,..... Welcome Aboard,..... What vintage is it,..?? What's the alarm test,..??
dubs283
Most likely corrosion, faulty ground(s), deteriorated wiring, loose/worn connections, stripped/crossed wire(s) or someone changed wiring the incorrect way
