flukin2601
- Aug 7, 2018
- 6
Hi all, been a long time follower but could never find the time to sit down and type until now. Thank you for your info, help, and reply's, I hope to try to contribute back to help make the board successful. Here's what I have:
Mercruiser 5.7 Mag/MPI 350 Serial # 1A040331 with B3
2007 with 780 hrs. 250 were Fresh (prev owner), and the last 530 were in Salt
Boat is always trailered, ALWAYS flushed with fresh water and salt-away after every use.
I am the backyard DIYer and do the winterizations & tune ups, maintenance.
Problem: Had the boat out several times this season. 2 weeks ago, day out on water ran good, came home put on muffs, boat ran very rough and stalled. Pulled plugs and found water in all of starboard side, port side was completely dry. After some head scratching, decided it was over my DIY capacity and took to marina shop ( i was thinking it could be a head gasket) .
Compression : 8 - 150 7- 150
6 - 200 5 - 195
4 - 180 3 - 190
2 - 200 1 - 180
Shop advises we replace exhaust, risers, and gaskets. Rust was around exhaust manifolds on heads and riser. Rust was very prevalent inside starboard riser. Inside starboard exhaust, there was rust and an obvious water line? I agree to replace both risers and manifolds. I also had an oil leak in bilge which I could see was leaking from the rubber tube at bottom of pan, it was alot but I kept the oil level by continually adding oil (stupid, stupid...I know). Further inspection at shop showed flaking of rust under pan. Shop advises to pull motor and replace pan. Agreed and Done. Oil had minimal creamy oil when drained, I had done this prior to taking to shop. The pan showed maybe a teaspoon of the milky oil in pan. However when inspecting the pan, there was a blister inside, picked at it and found 3 pin holes. In my ownership of this boat, yes I have had water in bilge and my winterization could of been suspect, yet the boat ran good for 8 or so times this season (but did burn more fuel than usual). Shop also replaces exhaust flappers which were limp, agree and done. Engine reassembled and started up and ran ok out of the boat. Engine then dropped in and buttoned up and ran good at marina ramp in river. This was a very costly marina visit I may say and I have exhausted all my funds for another shop visit. Marina owner gives it a thumbs up and attributes the water to a possible cracked riser, or manifold, or bad gaskets.
3 days ago: Launched and ran for 4-5hrs, engine was 165 temp, on and off several times at sea, drifting but not WOT (too rough seas). Flush at home, no issues. Next day did run hard to 1st spot, 165-167 temp. Turn off, drift for 10 min, then reverse ran rough. Shut off for 5 min, try to restart, engine kinda cranks then starter spins with no crank? Hydrolocked is what I believe happened. Get a tow in, next day remove plugs on STARBOARD side, 4 & 8 have water pouring out and 2 & 6 are soaked. Port side is completely dry. Oil level from dipstick seems ok.
Question: With one side that has water, the other none could this be a head gasket, cracked intake manifold, cracked head, or pin hole in head? If it is any of these, what would be my next course of action? TY in Advance
6 - 200 5 - 195
4 - 180 3 - 190
2 - 200 1 - 180
