Mercruiser 5.7 surgeing.
BBDartz
1997 bayliner ciera 2655, new to me, low use Michigan boat surges on plane for 1st 15 minutes then runs fine until the next cold start. I have fresh gas in it now with sea foam and new water/fuel filter. Any ideas?
welcome aboard
please tell us a bit more about your motor (serial numbers help)
is it Carb or EFI?
have you inspected the contents of the fuel filter? (check for water)
BBDartz
I believe it’s 210hp, 2bbl carb, Rochester I think, gen I mercruiser. I dumped the contents of the previous fuel/water filter in a glass jar and all I got was clean gas, previous owner said fuel was stabilized prior to off-season storage. Sorry I don’t have serial # at home to provide right now.
if its a carb, surging is normally gunk in the carb. you may want to consider getting a carb kit and going thru the carb.
BBDartz
Ok, that’s a good suggestion, a good ‘boat related’ winter project perhaps? If I end up screwing it up rebuilds are not ridiculously expensive, I’ve already bought two carbs this summer from a outfit in largo in your state. A quadrajet for a small block and a 2bbl for merc. 470, around $300. Per..
Silvertip
Did you not see the NOT ENGINE TOPICs in the forum title? Scroll down the page to the Mercruiser forum. You get much more visibility there.
JASinIL2006
Silvertip is just being helpful... he's right that posting this in the Mercruiser forum will be more likely to generate helpful responses.
This site has really great moderators, but we all try to help new members navigate the forum, both to help the newbies as well as to maintain some order around here.
Welcome!
southkogs
Scott's got ya' going, but Silvertip's right - you'll get better exposure and additional answers in this forum.
Welcome aboard.
