Hello,
My son replaced my 1996 5.7 Mercruiser, two barrel, pre-vortec engine in our 20' Reinell due to a cracked block. The engine was rebuilt by a professional rebuilder.
They were unable to find a block drilled for a mechanical fuel pump and so we installed an electric fuel pump (Sierra 18-7326). Also put in a roller bearing cam and flat top pistons. Replaced points, plugs, cap, wires, fuel filter, bellows, etc. as well.
Engine runs great in neutral but underway seems to run out of fuel at at about 2800 to 3000 RPM. If you pull back on the throttle it will avoid stalling. We can not get it up on a plane.
We thought maybe it was a fuel issue, but used an auxiliary tank with clean fuel and the same thing happened. My son thinks a four barrel carb is needed, however my brother-in-law thinks increasing the float level of the original carb would fix it. I wonder if it is something else such as a vacuum leak, bad fuel line, or maybe something in the carb.
We are at our wits end on this!
Has anyone had a similar experience?
Thanks!
Thanks!
