Mercruiser 5.7 no trim up or guages
burkey41
Got my boat out the other day with 5.7 Mercruiser (engine serial #0F065074) went to trim it up with the three way switch on the throttle and trim up would not work, nor did any of my gauges. Trim down works as does the trailer trim up button. I am able to measure12V under the dash for all switched accessories, but no nothing on gauges. Does anyone have any sort of wiring diagram, as I am not sure where I am losing voltage to the trim switch and gauges?
capecodder116
I agree most likely wires are rotted at transom or on drive. Mine operates same as you describe. I just run my trim using the trailering buttons. No big deal and not worth tearing everything apart to replace the wiring. You should be able to tell just by listening when you drive is properly trimmed.
Evinrude Boater
I have the same condition as the OP. My concern is that if I don't fix it some day the outdrive won't go down due to the deteriorating wiring. Is that a possibility?
JASinIL2006
The wires that they are referring to as rotted at the transom or the drive are the wires that connect the trim limit switch (sets upper and lower limits on travel of the drive) and/or the trim sender (sends position signals to the gauge on the dash). Those can be completely bypassed, if one wishes, and the drive will still function. Without the sender wires, the gauge simply won't work. Without the trim limit wires, the travel of the drive up and down is a function of whether the pistons are full extended or retracted.
The trim/tilt function is controlled by a hydraulic system that is more or less independent of those rotted transom/drive wires (excepting when the trim limit switch kicks in). It is not an uncommon practice, when a trim limit switch fails, to just jumper the wires past it. This allows the drive to raise and lower fully from either the trailer/tilt button or from the trim buttons. The only downside of this is that, when using the trim feature, you have to be careful not to raise the drive too far while running. Otherwise the U-joints start to protest...
