Mercruiser 5.7 block drain plug size
jthor3277
Good day -
Would anyone happen to know the engine block drain plug size for a Merc 5.7L? I removed them last winter and I don't know where they went!
Don S
Re: Mercruiser 5.7 block drain plug size
If you are referring to the brass pipe plugs that fit into the block, they are 1/4" NPT.
Or are you looking for the blue plastic plugs?
jthor3277
I was looking for the Brass pipe plugs. I don't have the adapters in my block for the blue plugs. Thanks as always!
Ayuh,... 'n That's a Good thing,...
jthor3277
Hi Bondo. Just curious to why that is?
edthecritman
Re: Mercruiser 5.7 block drain plug location
I cannot find where all 5 plugs go - can you help me?
Bt Doctur
best to start your own post next time. not knowing the year or serial number I`ll guess 2 go in the block, 2 in the manifolds.the 5th?
start it and see where water leaks out of.
Ayuh,... 'cause the blue plugs are plastic, 'n break off,...
A brass plug with wrench flats, Won't...
Don S
As mentioned before edthecritman, you need to start a new thread of your own with your information. This thread is about jthor3277's question.
