I have a 95 Merc. 5.7L I/o raw water cooled getting air in the cooling system. The problem was first noticed by water temp fluctuates 100-150? in seconds back and forth. First thought it was an indication problem so changed sensor, not it. Changed thermostat 140? ,not it. Then noticed cooling hoses chugging. Now I figured it was a head gasket. Did a compression check all cylinders at 120 except 8 at 0. Pulled the valve cover and found #8 cyl intake rocker stud pulling out of the head so intake valve was not opening.. Removed the head and had it repaired. Just reinstalled the head, new gaskets and started the motor. Still have temp fluctuations and hoses chugging (seams like air). Any thoughts about what is causing this??
