Mercruiser 5.0L alpha, 2007, milky oil
CaptL
I have replaced the manifolds, risers and elbows but I still have milky white oil, help? What do I look at next?
tpenfield
:welcome:
Yes, pressure test, as in cracked engine block.
Tell us a bit more about the history of the engine/boat.
jones01m
CaptL, It turns out I just went through "milky" oil on my rebuild last week. You can see if your situation aligns with mine as articulated in the 1976 century thread. The problem ended up only being very humid air and condensation. My engine did not run long enough to heat the oil to adequate temp to steam it off. Oil went from milk to brand new after about 45 minutes of running in a test stand at around 160F water temp reading.
Lou C
Has this engine ever overheated?
Was it always winterized promptly?
