Mercruiser 5.0 MPI Starboard drain plug access tips/tricks?
jsharp2000
I can't seem to access the two drain plugs on the starboard side of my 5.0 MPI Mercruiser. I put a quick video showing my setup. Are there any tricks to getting into this tight spot that I'm not thinking of? https://youtu.be/1s4s0rjejdM
welcome aboard.
hang upside down over the motor
you may have to unbolt the bulkhead and the panels to the sides of the motor
alldodge
Could use the motor serial number to verify things
That motor is wedged in there, and may need to remove the alternator to provide enough room to get in. Either that or find someone with smaller hands. If your hand is being stopped by the manifold water hose, remove it
Looks like you have what is called the 3 point drain system with a Bravo out drive. The one your not able to get to is the seawater pump drain. Another thing to note, is the fuel module (also on starboard side) needs to be drained.
Lou C
I would remove all those bulkheads and get them out of the way. That's what I do on mine, and while taking out the back seat and removing them takes about 10 min it makes the rest of the job much easier.
QBhoy
It’s just out of shot, if it’s there, but do you not have a blue handle on the front port side of the engine ? The multi point drain system ? Perhaps someone has disconnected it previously ? The drain you show on the front of engine down low is where that normally drains to bilge through an orange hose.
