Miss"T"Blue
- Jun 10, 2012
- 6
MerCruser 5.0 MPI serial number OW364510. No start typically occurs after engine has been run awhile. Suspected vapor lock. However, problem has occurred while attempting first start of day. Replaced Idle Air Control (IAC) valve but problem still exists. Only solution to re-start is to remove the fuel filter and fill with fuel and re-install. Engine starts fine after this procedure. When fuel filter is removed following no-start problem, filter is dry. Engine performs fine when running, plenty of power sand idles smooth. Any help / suggestions are appreciated. Thanks!
