I have an 01 Mercruiser 5.0 with a 2bbl carb and thunderbolt v ignition, boat is bone stock, recently I have developed a misfire above half throttle, I found a loose battery terminal so I replaced both terminals, I also replaced plugs, wires, ignition coil and rebuilt the carb, I have a cap and rotor on order but mine looks okay, I ran it in my driveway for at least 30 straight minutes, half at 4k rpm and half at idle, it seems after all that the problem has worsened, now I’ve been flooding at low rpm’s and the misfire has gotten worse, idk what else could be wrong, I need help to determine what else could be causing this, I’m at a loss
