Mercruiser 470 Temp
yamhoss86
I changed the heat exchanger from the 3" to the 4".
The engine does run a bit cooler and does cool down much faster with the 4" heat exchanger.
I am running about 180 at 3/4 throttle. Is that normal?
I did notice that at some moments when i did go 3/4 throttle the engine temp would go up to 180 then back down to 160 and stay there.
I don't understand...any help would be appreciated.
Thanks.
SDSeville
Re: Mercruiser 470 Temp
Not an expert, but that sounds a little high. Mine runs around 150. How is your your impeller?
My 3.7 aka 470 with the 4" exchanger... will run at 160?F all day long.
Here is a list of the impeller Kits avail. from Mercruiser:
What year is your drive and I can give you the correct part numbers
  • MERCRUISER WATER PUMP REPAIR KITS - DRIVE.pdf
stonyloam
If it has been more than 2 years since the impeller was changed, change it! If your impeller is failing you are courting disaster.
yamhoss86
I changed the impeller this year, when the guy was replacing the impeller, i noticed that one of the fins was facing in another direction. Is that a problem?
yamhoss86
Its a 1981 model
stonyloam
It should flip around when it was first run. Check for a restriction in the water outlet in the exhaust elbow. Pull the hose off and attach a garden hose to see if the water will flow out of the outdrive without restriction (no or very little backpressure). Also check your temperature with an infrared thermometer to make sure your gauge is accurate.
Just reread your initial post, if the temperature goes up then down your thermostat may be hanging up.
achris
More fish than mountain goat
Hey Terry, Try to send you a PM, but ya box is full... :facepalm:
Here's the PM anyway (OP, sorry to have to do this)
Hey Terry,
Been looking at dwell/tach digital meters for some guys.... There is a LOT of them out there, but check this one out.... Got the LOT! Dwell and tacho for 1,3,4,5,6,8,cylinders, all the usual electrical functions (V,A,Ω,diode,buzzer), capacitance, thermocouple and bipolar transistor tester... And here's the best part.... $26... and free postage!
Digital Tachometer Meter Tach Dwell Tester Multimeter Ship From USA | eBay
You really gotta get one of these!!!
Cheers.....
