Mercruiser 470 Shifting hard into gear when engine is running
yamhoss86
My 81 Mercruiser 470 is shifting into gear very hard.
When i try to go from forward to neutral (while the engine is running), i have to shift very hard.
Sometimes it goes from Forward to Reverse in one shift.
It has become very hard for me to dock the boat. Not sure what to check/replace.
Many thanks for all the advice.
yamhoss86
Re: Mercruiser 470 Shifting hard into gear when engine is running
Bump
Ayuh,.... My guess is 1 or more of yer shift cables is bindin',...
Disconnect 'em at the shift switch plate, 'n see,...
Most common is a worn lower shift cable which runs from the shift bracket on the engine out to the bellhousing.
How old is yours?
