Mercruiser 470 possible electrical problem
deanehorn
As I am cruising, at fairly low speed (2000rpm) for maybe 20-30 minutes, the starboard engine suddenly shuts off with no warning. Seems to be running fine while running. After engine shuts down, it will not restart until it sits for 15 minutes or so. I even tried spraying starter fluid in the carborator, and it just turns over with no intention of starting. After sitting and then started, it will run for another 2 - 10 minutes before shutting down again. The port engine has shut off unexpectedly in a similar manner but it will restart immediately and then continue to run. The port engine seems to be a little on the hot side according to the temp gauge. Any ideas on why the engine might be shutting down?
JB
Re: Mercruiser 470 possible electrical problem
Moving to I/O
