Blazeracer
- Mar 31, 2008
- 14
Ok, well I got to deal with a melted regulator and about 18 volts running through my boat the other day. Fortunately the only thing that got hurt appears to be the electric fuel pump. I've done a lot of reading and tried something on a whim today that cost $40 and probably fixed it for good. No alternator kit needed.
From what I gather, the stator set up on a 470 is quite reliable. It is nothing more than magnets spinning around each other which generate an alternating current. Well, the old Fords used an external voltage regulator that has a built in rectifier, just what the stator needs to make it useful. Oreilly Auto Parts has the Ford external electronic regulator under part number F400 for $38.
The two leads that come out of the stator will connect to the F and S leads, the red NON SWITCHED wire will go to the A lead and the I lead will connect to any switched wire. I used the one on the starter solenoid since it's in close proximity. I just did it for $38 and my charge holds ROCK STEADY at 12.8 volts. Wha-Laa
Make sure you use weather proof connections and this is probably not good for salt water, but I only use my boat in Dallas area lakes.
Oh, the original regulator is still in place with all the wires removed. The Ford regulator is bolted on top of the Mercruiser regulator which kinda hides it.
No alternator, no charging nightmares, $38.....
