Mercruiser 409 engine severe vibration issue
Voyager NY
I recently purchased a Certified Pre Owned (CPO)engine from Doug Russel Marine. The engine was installed and at first start up i noticed a high vibration from the engine , this is before the drive was installed. The engine was aligned with the coupler ,drive installed and boat launched. The vibration was immediately apparent while under way. After reporting the issue to the marina mechanic it was thought to be a misfire. Now after extensive evaluation by another certified merc mechanc and mercruiser tech support the vibration at all speeds is still there.This is what has been done new plugs cap and rotor change engine coupler, remount sea water pump(it fell off) change motor mounts, replace oil pressure sender(it fell apart) oil changed from 25-40 to 25-50 My question is does anyone out there have a 409 and have you experienced excessive vibration (the whole boat is vibrating to the point everything is shaking, coffe cups jumping out of the holder.
Please help
alldodge
Did you swap a 409 for a 409, or another motor to a 409?
something is most likely wrong with the base engine level. did they use the old flywheel vs the flywheel on the 409?
as AD asked, what was there prior to the 409?
there should be no vibration strong enough to shake a coffee cup or brake sea water pump fasteners.
did you mechanics do a power balance test? that would tell you if you have a dead cylinder.
Ayuh,...... is this an over-bored 400 SBC, or an over-bored 396 BBC,..??
I haven't heard the term 409 since the beachboys did that song, my little 409, back in the '60s,.....
Scott06
Cant tell if it is a chevy based or not valve covers look different but overall configuration looks SBC based
either way the the CPO version is a heck of a lot less than the new ones...
its a mercruiser only block casting running the SBC pistons with a 4.035" bore (max you can go in the block) and a 4.0" stroke. its running a holley throttle body
because Mercruiser did not want to use the GM LS motors
Rod ratio is horrendous, and the crank requires a custom flywheel (like the old 400 SBC's
supposedly a flat plane crank (useless in a boat under 6000 RPM), that may be why its vibrating. flat plane cranks work best with really really short strokes like 3" stroke and 4" pistons.
Voyager NY
Please help
There was a 383 mpi in there previously and the engine is a new CPO motor from quicksilver designed 409 for a direct replacement for older 350/383 engines,this motor is from merc.
Voyager NY
also I am using the new flywheel that came with it. The harmonic balancer is a liquid filled ballancer
Voyager NY
Please help
YES It has a flat plane crank
Voyager NY
Please help
Compression test was done and spark plugs all burning the same, the initial thought was that there was a misfiring cylinder
Voyager NY
My thought is at this point is that the motor has a internal balance issue but merc is fixing all the things that are breaking due to the vibration but are saying that the vibration is normal. I could see at idle due to the flat crank but this vibration is at all rpm's The LP fuel pump and the oil filter are shaking wildly
Voyager NY
Please help
By the way to everyone I really appreciate your reply's
cyclops222
We now understand why the previous owner sold the motor.
Good luck with a very unusual problem.
cyclops222
By chance does that engine have a engine dampener on the front of the crankshaft ? Is it the correct one ? And correctly timed to TDC of piston ?
alldodge
Merc is replacing things at no cost to you?
Voyager NY
No, so far it is not at no cost to me. The initial diagnosis for the vibration has not been covered $1,400 and no resolution has been found. Merc is paying for the results of the vibration as one offs. What about the damage to the crank and bearings how long will they last being run with this imbalance.
