Well It's been a long story.
A few years ago I went to start the boat and just a click.... got all the schematics off here to troubleshoot, and narrowed it down to the starter. Replaced starter, ran perfect.
Now this year, same click, troubleshoot list again and this time it is the remote starter solenoid, so I order one, leave the boat tied to the dock overnight.
Boat gets hammered by waves, drenched under the hatch and takes out the dock, decide I need to get it out of the water, try to jumper the solenoid, it turns over like crazy but won't start. Walked it to the beach and try to load it there, whole nother gong show but get it out of the water eventually.
Leave it sit at campsite until the solenoid got here. Replace remote solenoid, now cranks over like crazy at the key but doesn't start, watching down the carb as it cranks over the carb is bone dry no sign of fuel. Read it might have got water in the bowl (it did get spalshed lots) and won't let gas through so take the carb off and drain it upside down, lots of gas was in it somewhere for looking bone dry. Turn engine over with the fuel line off the side of the carb and it pumps gas into a little jar so fuel is getting to the carb.
Start second guessing that it isnt fuel so test the coil, and all plug wires coming of the rotor all are firing, verify the fuel pump makes noise when the key is on and for the five second after turning over so the oil switch is working. Also jumkper the oil swithc leads so the pumps runs constantly and still looks bone dry down the carb.
Decide to start manually pumping the throttle lever, this seems to be working and it seems like is firing a bit and about to go, realize if I pump the throttle lever a bunch and then try to start it but at idle it will start and run for a bit, if while idling i try to give it throttle it dies, seems to only run for as long as I manually pump the lever. The more I pump the lever ahead of time the longer it will idle when I start it, but still never longer than maybe 20 or 30 seconds.
So In summary, I think the pump, filter/water separator, pickup line, and antisyphon valve are good as it pumped fuel into the jar. All the electrical for ignition and fuel seem good, I think the throttle pumping seems to get some fuel into it but only for a short run. The fuel is getting into the carb, and even being stored somewhere you cant see, but none is getting from there into the engine.
So is this a stuck float? Plugged needle valve? seized doohickey?
