Mercruiser 4.3l TKS water drain plugs
bullbear1
I have found where 4 of the 5 blue water drain plugs are located. I can't find the fifth. Does anyone have a diagram showing where the 5 drain plugs are located?
Don S
Re: Mercruiser 4.3l TKI water drain plugs
Do you have an engine serial number. Did you mean TKS instead of TKI ?
Might have a look at the bottom of the large hose coming out of the engine circulation pump.
bullbear1
It actually is a 4.3 l model MCM. 2006 engine.
Don S
The reason I ask for a serial number is because NOTHING Mercruiser does is by year. All by serial number. Parts are listed for 98 and newer. Then you have go by serial number range.
bullbear1
thanks. The engine serial # is OW656481
Don S
I was thinking you wanted to drain it, I see now you are just looking for where the plug goes.
Would have been easy just to start the engine on muffs and seen where the water was coming from.
attachment.php
bullbear1
thanks. That's what I need.
Pete104
Don, can you please change titles on this thread? It goes from TKS on the opening question. Then, after your first post is TKI.
