Re: Mercruiser 4.3L - - Location of Engine Drain Plugs
There are total 5 drain plugs for this engine.
You can see one obviously in the front of engine on left bottom near the water pump fly wheel, (Blue plastic drain plug)
One on each side near engine mount, they are manifold drain plugs.
One on each side just below the manifold drain, they are engine block drain plugs.
