Hey everyone, need a little help diagnosing a temp gauge that isn't working. Just bought the boat, the gauge was stuck pegged all the way, always, key on or off. I pulled the ground wire from the back of the gauge and cycled the key and it swept back to zero. When I put the ground wire back on it maxed out again. I removed the wire from the sender and using a jumper from battery ground i can get the gauge to bounce from zero to max. Does this mean I have a bad sender?
