ahspriteguy1
- Aug 6, 2013
- 5
I have a 2006 Mercruiser 4.3, sometimes it starts right up but usually it takes 5 or 6 tries. I have read other threads and found the attached trouble shooting a starting system. It makes it easy and everything checked out until I got to the slave solenoid. Again to clarify, my issue; I turn the key and just hear a click. I'll do this a number of times and finally it will immediately turn over and start. On the attached instructions #4 for testing the slave with attest light, it says to touch terminal J and it should light up. It does not but if I touch terminal k, the one closest to the two small terminals I get light. In #12 when I recheck J, its the same thing and I cannot get the small terminal M to light when the key is turned to start. They say this indicates a wiring problem between the neutral safety switch and the slave. HERE IS THE KICKER - If I jump the slave, the starter turns right over BUT my slave solenoid is hooked up backwards from the attached diagram - it shows the yellow wire connected to the large terminal closest to the two small terminals and the red wire on the opposite end. On mine, the red wire is hooked up to the K terminal closest to the two small terminals. This probably explains why J won't test light and why K will -because its wired backwards. Is this true is it wired backwards? if so why does it start after a few tries? I thought about switching the wires but thought if it is correct, it might fry something. my solenoid looks just like the one in the diagram.
Any help is appreciated!
