No magic but rather a process of elimination. Like the classic Clue game, need to figure out if its Colonel Mustard with the lead pipe or Professor Plum with the rope….
Given the motor turns over by hand, there are two basic potentials either the Starter or the Flywheel. Based on your post it sounds as if you have checked the flywheel for any missing or damaged teeth. As you many know this requires checking the
entire circumstance. This only possible with the starter removed and then viewing the flywheel one section at a time by slightly rotating the motor and checking the next section. Repeat until the entire flywheel has been inspected. Mark the flywheel at the start to know you have inspected the full 360 degrees.
Based on the video you posted it does seem as if the flywheel is OK. This is based on the starter spins but the motor does not initially. And then without turning the motor by hand, at the next turn of the key, the motor does rotate but stops while the starter is still turning. So is like this:
- (1) Key to start > Starter motor spins, motor does not. (2) Key off. (3) Key to start > starter AND motor both spin but suddenly the motor stops rotating but can hear the starter motor still spinning. (4) Key off and frustration/confusion.
This leads me to believe that the starter is the issue. Specifically, the starter
overrunning clutch. Said differently it seems as if your starter is engaging (the pinion gear gets pushed out to the flywheel and engages) but the overrunning clutch is intermittently failing allowing the motor to turn but then (under load) fails. Thus even with the pinion gear engaged and the starter spinning it does not turn over the motor.
Overrunning clutch? This is the device between the starter shaft that spins and the pinion gear that engages the flywheel. In AllDodge’s picture it’s the device just behind the Pinion. When the engine starts the pinion gear is still engaged with the flywheel and this device allows it to ‘run faster’ than the starter motor. Is akin to the 3/8 Inch Rachet you use on your Socket Set. It will ‘lock up’ one direction but spin in the other. Here are a couple of vids on this device
link and
link.
So, while you have a new starter, it does not mean that it is good. Try another starter is my suggestion.
