I have a 1996 Larson 280 with twin Mercs. One of them started overheating this weekend. When I brought the throttle down, The temperature dropped. The temp readings went from 100- 250 on and off. When I finally got back to the dock, I turned the key off, but the engine kept sputtering and did not shut off immediately. I recently changed the water pumps in the out drives, so I doubt that is causing the overheating problem. Not sure if the sputtering could be related?
