Hello everybody,
I have a problem with a Mercruiser 4.3L MPI - year : 2017 - hours : 21h !
The engine start good and works almost good (not perfect), but it shut down at the idle with no alarm, no mecanique problem..
So I look for again and again, I control every thing, I change the IAC, same problem.
But today I find something ! I disconnect the hose between the PCV valve (on the valve cover) and the intake manifold, after that the engine works good ... (you can see the picture, it is the hose disconnect).
I think it was the PCV valve dead, so I remove the valve cover, but every thing is good.
The engine works good now with the hose disconnect but I want to understand what is the problem ! :O
Somebody have see this problem ?
Thank you.
Thank you.
