mguardado7293
- Nov 8, 2021
- 5
Hello every one, I have a 1993 mercruiser alpha 4.3l v6 on a 93 sea ray
Last week my starter went out & I replaced it right away. But now when I got back in the water I started the engine and it started perfectly fine
30 min later I shut it off & it wouldn’t start anymore (only crank, no spark)
I determined I had a faulty ignition coil & I had a spare one in my garage from another boat (I also ordered a new one) .
when I swapped out ignition coil the engine fired right up, but after 15 min of running I shut the motor off and went back to start it and it wouldn’t run(only crank, no spark).
By then I had my new ignition coil in and I replaced it for a 3rd time.
once again engine fired right up and after about 5min of running, it shut off when I was going to switch from neutral to drive and it wouldn’t start again (cranks, but not spark).
I’m assuming the 3rd ignition coil is gone aswell.
has anyone seen this before?
Could me replacing my starter cause this?
