I just bought a 93 bayliner with a 3L Mercruiser sterndrive. Yesterday was the maiden voyage. First, it was hard to start until we held the choke open manually. Once we were able to start it, it reved up to 3000 rpm and wouldn't go back down. We had to bring the revs back down by closing off the choke. Afterwards, it was easy to restart, but still reved high. <br />I disconnected the throttle linkage to see if it was the linkage causing the problem, but the same thing happened. However, with the throttle linkage off, I looked down the carb and found the throttle baffles were closed. Why is it reving so high?<br />Another weird thing I found was the throttle cable did not seem to engage the carb linkage until the throttle handle was pushed forward approx. 40 degrees. The throttle linkage should start to engage the carb as soon as it is pushed forward from the vertical position, shouldn't it?<br />Anyone's opinion would be much appreciated.
