MerCruiser 383 Sterndrive to Inboard Conversion
PilotPat24
Hi Guys,
I am looking to convert a 2014 MerCruiser 383 Sterndrive engine to a down angle inboard setup. I currently have a 5.7 MPI in my boat so I would swap over my gearbox onto the 383.
Electronically, what needs to be done to make such a conversion?
The serial number of the 383 is 1G405281
Thanks,
Pat
Bt Doctur
Not a thing, you need a inboard bell housing to accept a rear entry starter, flex plate for the trans and a inboard trans, shaft logs, shaft strut ,shaft and prop and a rudder and move the motor forward about 10 feet with new front motor mounts
thumpar
The way I read it was that he had a boat with 5.7l MPI inboard motor and 383 sterndrive motor he wants to put in its place.
Hi Guys,
Thanks,
Pat
do you have the ECM for the 383 motor?
Bt Doctur
Dont know how he`s trying to convert. Dont know is its a running motor , a long block, what intake system. Is it even injected or carb`d.
