Mercruiser 350 Mag Horizon engine
astro4prez
Does this so-called "closed cooling" system still require a standard flush using the earmuffs on the outdrive (Bravo 3)?
Re: Mercruiser 350 Mag Horizon engine
Ayuh,...... It Sure Does.....
Don S
Yes, it will flush out the manifolds, risers, and heat exchanger and everything else on the raw water side of the system.
astro4prez
Update! This system draws water from the underside of the boat and through a sea strainer. The intake ports on the outdrive need to be blocked and a hose inserted into the strainer will provide the water to flush. NO MORE EARMUFFS!
