I was having issues with a sporadic idle and what I thought was a dead battery. I went and cleaned all the grounds in the electrical system and now when I go to start the engine the 90 amp fuse on the starter blows. No power at the gauges and no action on the ignition. I'm thinking its the starter itself as when I was cleaning contacts I noticed one of the terminals on the starter solenoid was loose. I want to test to make sure its the starter not the alternator or another short. I have a multi meter and want to check resistance. Can I try starting engine with the alternator disconnected? Can I hook up the harness connection which was on the fuse to a separate battery so I can test the starter itself?
