Meisenhuth5
- Mar 15, 2014
- 4
Hoping to tap into the vast knowledge of folks here.
I picked up a Wellcraft Nova 23 XL over the winter as a project boat and have confirmed some of the issues from the previous owners statement. The previous owner stated that after cruising the oil pressure would drop and the idiot light would come on. With that statement I immediately plumed in a permanent mechanical gauge.
Now for the nitty gritty. When i took her out thursday, the cold idle pressure on the mechanical gauge was 35psi and maintained that while cruising through the no wake zones. After getting on plane and running for 10 minutes (pressure was up to about 65) i decides to slow it down and put it neutral, the pressure dropped to about 3 psi and the idiot light came on for a split second. the pressure will slowly build again if left alone, or will jump right up if i give it a little throttle. What are you thoughts on this, bad bearings? How long would somebody run with this issue? I was hoping to get a little enjoyment out of the boat before tearing her down this off season to repair some soft spots in the floor and possibly re-wiring the boat neatly and correctly.
If bad bearings would you recommend just pulling the motor and replacing bearings or get a reman'd motor / getting this one machined?
Thank you in advance for helping me out.
BTW i also just changed the oil with quicksilver 25w-40 with new filter. The pressure was the same on muffs before and after the oil change.
