Mercruiser 305 distributor breather
mudweiser
Working out the bugs on this 1989 305 mercruiser. It has the stock merc distributor. I noticed there is a brass breather on the side of the distributor. Is this just a breather or is is vac. advance? If it's an advance, where does it hook up to, There is no open connections on the carb.
Re: Mercruiser 305 distributor breather
Nope,.......
That's Just a Breather,...... Sparks Can't go around corners,.......
FreeBeeTony
I believe what you're describing is a vent.........not a breather.
Nothing connects to it.
Ayuh,......... Good to see ya Tony................;)
mudweiser
Wow, fast response. Thanks.
