mercruiser 3.7L water in oil HELP
poolshells
I have a 3.7L 1989 water leaks from fresh water cooling system into oil without the engine running any sugestions HELP Thanks Ed
Re: mercruiser 3.7L water in oil HELP
Ayuh,... Drain it,+ pressure test it with Air,... about 12/ 15psi...
You'll Hear the leak,+ gain some insight on Which way to go....
Don S
The engine circulation pump runs off the cam. The seal leaking antifreeze into the oil is a known problems with all the 470 (3.7L) engines.
poolshells
this seal is it under the front cover is it just a seal and a gasket replace
stonyloam
First of all you need to find out if that is where your problem really is. Find the little weep hole on the lower starboard side of the coolant circulating pump on the front of the engine. Make sure that the hole is open (clean it out to make sure). Start the engine and see if it is leaking from the weep hole. If it is not, it is unlikely that the "water" in the engine is coming from a bad cam seal. Couple of other things: Is it water or antifreeze in the oil? You should be able to smell antifreeze in the oil. Is the coolant level dropping in the reservoir? If not it is probably a seawater leak. If it is seawater, the only place I can think of as a source is from somewhere around the exhaust manifold. Maybe some other folks with more knowledge than I can take a guess. Finally If you need new cam seals, it is a PITA, but can be done by a do it yourselfer check out: http://www.sterndrives.com/470information/470coolantleakrepair.html
Good luck
zbnutcase
I rebuilt one of these couple yrs ago and the cam nose where the seals ride was so pitted I installed a speedi-sleave on it. However it has to be done after timing chain sprocket is installed and before the timing cover installed...but it CAN be done. 'nutcase
